Home > In Car Electronics (L322) > IID Tool Bluetooth ECU flash
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I’ve recently bought the IID Tool and have to say it’s awesome.
Definitely saved me money and has helped sort a few “quirks” out.
I noticed that there is a Bluetooth flash available in the menu, but could someone tell me what the flash will solve/mend?
Will it fix having to re pair my phone every time I get back in the car?
[/list] 2007 3.6 TDV8
Post #470792 3rd Mar 2018 5:41am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I dont think the IID tool will sort that. Email Gap themselves as they are very helpful.
For your phone issue you need the firmware updating on the bluetooth module.
See here
http://www.bluetoothexchange.co.uk 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #470820 3rd Mar 2018 11:21am
Crispian22
I did exactly that with mine after getting frustrated pairing it every time I got in,works a treat now Thumbs Up
Post #470822 3rd Mar 2018 11:29am
Clabs
Cheezels
^^^^^ What Crispian said.
I had exactly this pairing problem on my MY06 TD6 - having to enter 2121 every time to re-pair the phone, no phone book and poor sound quality. Reflashing via the IID tool was very straightforward and solved all those problems.
From memory it took around 25 minutes but just make sure your battery is fully charged before you start the process.
Cheers, Mark
Post #471063 4th Mar 2018 8:33pm
Grofus
Wow ok. Do you download the firmware update from the Gap website then? I need to get an IID BT then.
Been toying with buying one for a while. Neutral 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #471081 4th Mar 2018 9:56pm
Clabs
Grofus
I am not sure if I had to download anything - I use an Ipad with the IID tool and from memory it was all pretty seamless.
Having said that, the Ipad did have good WiFi access at the time.
I cannot recommend owning an IID tool highly enough anyway. Apart from being able to sort problems like this, it also gives you peace of mind that you can diagnose any issues you might encounter yourself along the road without relying on a dealer and you have the benefit of being able to customise many of the settings on your car.
If you sell your car, the IID's seem to sell for really strong money so to my mind, a bit of a no-brainer.
Post #471087 4th Mar 2018 10:41pm
cheezels
Ok. Went ahead and did the flash upgrade. Took about 45 minutes and so far all is well.
Will have to see if it solves having to put the PIN in all the time 2007 3.6 TDV8
Post #471100 5th Mar 2018 6:43am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Yes it cours that problem Wink Had mine flashed by one of the german forum and i am really happy now! Pairs automatic and i have phonebook also the latest, missed and recieved calls. What a revolution Smile
Post #472155 11th Mar 2018 5:32pm
TJH1985
Wish we had gone IID! We have a DA Dongle and for some reason we can’t read the SUB_MOST which includes the tel ecu so can’t flash it Big Cry
Post #472160 11th Mar 2018 6:01pm
