Home > Maintenance & Mods (L405) > Electric towbar parts required
AndyS
Can you let me know where I can find a parts list so I can identify the correct bits needed to fit a deployable tow bar. Thinking of buying a used one off Fleabay but they don't often come will all the necessary bits.
I think I need the following:
Towbar (obviously) Whistle
ECU
13 pin electrics
ECU/module
Switch for rear side panel to deploy
Anything else needed?
Will be for a 17MY car.
Post #470941 4th Mar 2018 11:11am
not sure if these will be on there but try the russian microcat.. ... - .- -.
Post #470948 4th Mar 2018 12:22pm
Baltic Blue
If you have got access to Topix and your Vin No. you could pay for a couple of hours and download the relevant Workshop Manual section as a PDF.
Post #470950 4th Mar 2018 12:29pm
There is a frame that needs to fit to the floor of the boot to reinforce it... As the shell in Ali it doesn’t have the structural strength to add just a tow bar I’m afraid... Thumbs Up
Post #470968 4th Mar 2018 2:18pm
