Home > Technical (L322) > L322 2002 Front Subframe
W14shp
Just had the fattie TD6 to my mates garage to sort suspension inactive, took a look under neath and found a hole in the front subframe.
New is £800+vat, on a search my understanding that the 4.4 petrol subframe is the same as a TD6 is that correct? Also how long do they take to change, will be done at an independent garage.
Post #470554 1st Mar 2018 2:59pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Hi, I've got a front subframe available listed it in the "For Sale" section if you're happy to save a few hundred pounds... Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #470610 1st Mar 2018 8:02pm
W14shp
Can you give me a price and a photo?
What kind of condition is it in?
Thanks
Post #470681 2nd Mar 2018 12:49pm
Zebedee
It's reasonable. Solid, though has some surface rust - nothing flaking off, just the black powder coating is missing off some/most of it.
I was asking £125 in the For Sale section, though would do it for £100. Not great pictures, though you should get an idea...
 Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #470698 2nd Mar 2018 3:20pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Would only cost 50 quid to have that blasted and powder coated , so big saving on new 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #470705 2nd Mar 2018 4:03pm
W14shp
Presume it's the main front subframe and the subframe with the towing eye?
Post #470738 2nd Mar 2018 6:56pm
Zebedee
The engine subframe and front towing eye subframe are 2 separate parts. All of this is now off the car. From memory, the engine subframe is held to the body by 4 bolts and to the engine with 2 engine mounts. The steering rack is also bolted to this subframe. The towing eye subframe is bolted to the the engine subframe and the front chassis legs.
So to change it, I’d guess you have to support the engine, undo the 2 steering rack bolts, undo the 2 bolts attached to the towing eye subframe, then the 2 engine mounts and the 4 bolts that attach the subframe to the body and it should come off. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #470799 3rd Mar 2018 8:10am
