![]() | Home > General > A question of snow... |
longmanh Member Since: 11 Feb 2018 Location: Thames Ditton Posts: 104 ![]() ![]() ![]() |
I would say the XF. Winter tyres make such a difference. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6744 ![]() ![]() ![]() |
Judging by what I saw in Glasgow yesterday, the FFRR |
dinosaurjuice Member Since: 11 Jan 2018 Location: Lancashire Posts: 20 ![]() ![]() ![]() |
The FF gets my vote. If it was a FWD car with winter tyres it would be better IMO. RWD cars just don't work in snow no matter what in my opinion... MY11 4.4 TDV8 Vogue SE |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
If you mean the roads around here (Hampshire) the answer is "neither". Because the road will be blocked by stranded cars, especially "premium German saloons" with low profile tyres.
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 141 ![]() ![]() |
Main issue certainly is other cars. I tend to stick to more rural roads on the way to work in these sort of conditions. Having said that I had to make a hill start on a steep snow covered road this morning and it did struggle to get traction initially, made it without major issue but the traction control was working quite hard. A decent set of M+S tyres would have made quite a difference (or the full winters curently sitting in the garage !).
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Thanks everybody!
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
Snow |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
The one with winter tyres - as many have pointed out stranded traffic is the challenge to moving, but you’ll be glad of the winter tyres when you need to stop to avoid the numpties 4.2 SC - sold , now bought back
Biggles1957 Member Since: 05 Dec 2017 Location: Leicestershire Posts: 28 ![]() ![]() ![]() |
Well.....my Morris Traveller just cut through all the snow a few years back when we had that rough winter. His little 145 tyres - and rear wheel drive - allowed me to go back and forth to work every day regardless! Used to see lots of 'premium German' on stupid fat tyres stranded everywhere but Monty went through it all. Mind you, I had fitted Traction Control to him (a 3x2 slab in the boot!) and ABS because it was so cold my leg was trembling |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
All cars in my household have winter tyres in the past have sailed up snow covered inclines in a BMWwith winters past all sorts including FF my FF with winters has never had an issue and is even better at stopping in the dry when the temp is below 7 degrees so the Jag in my opinion |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7972 ![]() ![]() ![]() |
The FFRR will be better on fresh snow assuming a M+S tread pattern
I was out in my "plough" earlier. This thing really is unstoppable? |
GP 225 Member Since: 09 Oct 2007 Location: essex Posts: 22 ![]() ![]() ![]() |
Think you need to clear the snow from the roof of the car |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
proper play time |
