Home > In Car Electronics (L322) > Is it normal ?
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Is it normal ?
This may have been covered , but what is the tiny whirring sound coming from inside the dash all the time, when everything is off Imsure it must be draining the battery in this time of need .
Post #470030 25th Feb 2018 5:31pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I certainly have that too, so I assume it's normal!
When I've sat in there for a long time, it does eventually switch off, so I'm sure when you lock the doors it will switch off.
Post #470031 25th Feb 2018 5:44pm
Clivefog
Around 15 minutes when the systems go into standby. Bursts back into life when you open the door!
Been there done that so you don't have to lose 15 minutes of your life checking it out.
Post #470047 25th Feb 2018 7:48pm
mjdronfield
It could be the small fan pulling air into the air sensor on the heater unit. It’s behind the vent in between the left most knobs....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #470087 25th Feb 2018 10:14pm
nino_nino
+1
Post #470119 26th Feb 2018 9:30am
