Home > Technical (L322) > transsafe mode
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
transsafe mode
first time i have had this
so car this morning looked like battery wasn't great
but did start
drove 1 mile or so to drop son at rugby. on way back transfer mode warning came on, so pulled into a shop and gave it a few mins.
started to drive home and stopped at lights. put it in neutral when put it back in drive it didnt work. no drive
turned off the car and back on and it drove
so got home and stuck the IID tool in
got these errors
TBOX-Transfer Case
0x5212 Battery undervoltage (0x5212)
TCM-Transmission
0x36 Gear monitor 4 fault: General fault
am i right in saying its a battery thing?
s
Post #467230 4th Feb 2018 11:39am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Sounds like voltage issues. Charge or replace the battery and check alternator output etc. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #467237 4th Feb 2018 12:23pm
stcstc31
it must be something worse. just went to collect son, within 500 meters had no drive
getting back was fun
turned off car, had drive within meters do drive
Post #467263 4th Feb 2018 3:45pm
Grofus
RRphill is your man then 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #467285 4th Feb 2018 5:44pm
nebc100
Luxembourg 2003 Range Rover SE Td6 Monte Carlo Blue
Sorry to hear you are having problems.
I had a similar thing recently. I had the transmission refurbished because one morning I reversed out of the drive, and putting it in DRIVE, I went nowhere.
Afterwards, I would sporadically get an error saying Trans Failsafe Program.
It went back 4 times (in total) and they opened the whole transmission up again, and found nothing.
In the end, they checked the oil in the transfer case, and it was not very nice.
I have changed the oil, and since then (touch wood), I have not had any problems.
It might be an idea to check that because it is a cheap fix if it solves the problem.
Post #467738 8th Feb 2018 9:56am
stcstc31
so still dont have car back, full gearbox rebuild and 2.5k gone Sad
Post #470083 25th Feb 2018 9:46pm
nebc100
Sorry to hear it still isn't sorted!!
When you say you still don't have the car back, do you mean it has been at the garage all this time?
What has actually been done (so far)?
I am shocked that it isn't sorted.
If you were here in Lux, I would recommend a chap, but it is rather a long way from Ireland.
Post #470086 25th Feb 2018 10:07pm
stcstc31
got it back yesterday
running sooooo smoothly
all be it 2.5k lighter in the wallet department
Post #470662 2nd Mar 2018 10:02am
