Home > Maintenance & Mods (L322) > Rear washer...no washing cos there is no liquid!
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
thats because half of us have a f**ked rear wiper arm.
me included.. Laughing 2004 black Vogue TD6
Post #46962 21st Jan 2011 10:22pm
I hadn't even thought I had a problem. Thought my rear blade was shot but turns out the arms goosed. New arm to be ordered and then fix the water problem.
Post #47005 22nd Jan 2011 3:23pm
The rear wiper arm catches all the crap thrown up from the rear wheels and with the arm being tucked up under the spoiler seldom gets and washing or maintenance, so it's a must for changing every now and then.
Post #47009 22nd Jan 2011 4:23pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Can the rear wiper arm be replaced by just removing the rear spoiler ? How does the water pipe connect up ?
Mine is obviously blocked, I've stuck a needle in it and it worked a bit then just blocked up again.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #98381 19th Dec 2011 10:40pm
Yes it can it very easy.
Here's my how to from the wiki section
http://www.fullfatrr.com/forum/topic884.html
The pipe just pushes on, nothing complex. Discovery 4 HSE
Post #98389 19th Dec 2011 11:10pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
The spoiler can be removed in minutes, but place an old towel on the roof to lay the spoiler on as the brake light cable is quite short.
You can then remove the nozzle to give it a proper clean Thumbs Up
Gone - Range Rover Supercharged 2006
Post #98393 19th Dec 2011 11:12pm
CG-SC
Thanks..... Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #98394 19th Dec 2011 11:14pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
LR will blast air through it to clear the crud out of the pipe then it will work again. I had this on my last FF, i could hear the pump trying to squirt the water but no water. A blast of compressed air and viola, worked like a charm.
They didn't charge me when i asked for it to be sorted.
Post #98487 20th Dec 2011 2:08pm
I'm surprised they didn't charge you for the use of the Viola....
Whistle Discovery 4 HSE
Post #98517 20th Dec 2011 3:55pm
carlos50
Haha oops, spell check corrected it without me seeing it Embarassed
Post #98550 20th Dec 2011 7:11pm
Baltic Blue
I have just had mine in pieces and got 1 jet working well, but the second jet won’t clear.
I can’t get the wiper arm off to clear the second jet, any tips, is it just very tight on the spindle, or do I need a puller. ??
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #535970 30th Nov 2019 2:34pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Mine was a blocked nrv which can be cleaned carefully and replaced then cleaned and adjusted the jets all good now
I use a decent screen wash which I think keeps the lines and jets
I've have a post on here with some photos I'll dig it out Thumbs Up
Post #536023 30th Nov 2019 8:29pm
Henda
https://www.fullfatrr.com/forum/topic50730.html
I think that will take you there
Post #536024 30th Nov 2019 8:31pm
timse
England 2010 Range Rover Autobiography Black 5.0 SC V8 Barolo Black
I had a blocked rear washer and took the one way valve (OWV) out as that was knackered. Put a new one on and no joy. I read all the threads about taking the rear washer apart etc but thought there must be an easier way.
So, at the OWV I pulled the hose off on the side feeding the washer. This leaves about 4 inches of hose leading into the unit. I then used a small syringe (like used for Calpol or kiddies medicine) and filled it with Oust descaler and fed that into the tube. I felt the pressure so knew then it was blocked but sucking and pushing with that fluid then freed the blockage. I kept adding more oust until it cleared the nozzles and left for 10 mins after which I flushed with hot water.
Now have a working washer and only had to put the cards back inplace Smile
Thought I would mention as a first step before stripping out Smile
Tim
Post #541617 23rd Jan 2020 4:32pm
