Home > Technical (L322) > 4.4 TDV8 Gearbox behaviour |
longmanh Member Since: 11 Feb 2018 Location: Thames Ditton Posts: 104 |
So I took another vehicle for a test drive yesterday (this one: https://www.autotrader.co.uk/classified/ad...amp;page=6 and when pulling away from junctions on at very low speeds, I noticed the torque converter wouldn't lock up straight away so the revs would rise faster than the expected acceleration if that makes sense.
18th Feb 2018 10:04am |
Ok, that makes me feel a little better.
19th Feb 2018 4:19pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
I concur with TomCobley. It is actually quite noticeable sometimes from cold. :thumbs:
19th Feb 2018 6:14pm |
Thanks mate, appreciate the comments.
19th Feb 2018 6:31pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
I am so glad someone has asked, having had mine for just a month I was about to book it in to the workshop to have the gearbox looked at. Although mine does 250 miles each side of the week it does 2 trips of 5 miles on a weekday evening and I was convinced that the box felt like it was slipping when cold on those trips. Current Fleet:-
19th Feb 2018 6:35pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
I'd say the slightly strained engine note pulling away from standstill is about the only thing I don't like about my 4.4 TDV8. It just sounds a tiny bit coarse, especially when at all other speeds the drivetrain is sublime.
19th Feb 2018 7:36pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
I find acceleration off the mark rather slow because the torque converter is slipped to keep engine revs high unless using very gentle throttle. For normal use, acceleration would be much more brisk if the TC didn't slip so much. Perhaps acceleration is quickest under sustained wide throttle openings if the TC is allowed to slip. However I don't like the engine noise nor want maximum acceleration so lift off once moving sufficiently which then sends the gearbox into a frenzy whilst it works out which gear is appropriate.
19th Feb 2018 8:17pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Funny, I was going to ask a similar question to this.
19th Feb 2018 11:14pm |
Mine's TC will disengage on slow speed overrun even when hot. It does it every time after lifting off after going through a gateway at the top of a rise then turning hard right on a down-hill run. It re-engages when speed increases or the throttle is opened even just a little. |
20th Feb 2018 12:19am |
Mine will usually hold on to a gear when heading down hill.
20th Feb 2018 12:50am |
I guess the reason it has all these characteristics is to prolong the life of the gearbox due to the weight of the car. If it was a similar gearbox to the one say found in my E63 which is an MCT, it would just chew through the gears.
20th Feb 2018 7:37am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
When I had my gearbox oil changed recently, they did a software reset at the same time.
20th Feb 2018 8:51am |
I guess you can keep doing gearbox resets so the adaptations are relearnt each time or, carry out a gearbox reset, then drive it sports mode or via the paddles so it starts to adapt to a more sporty driving style. Might work. |
20th Feb 2018 9:16am |
I'm rather sceptical about this "learning gearbox" mularkey. I mean, my driving style is more to do with traffic, weather, time of day etc. etc. I don't mash the pedal to the floor since this is not how one should drive one's Range Rover. But seriously, I don't see how the gearbox can really be that clever when there's so many variables in play. |
20th Feb 2018 10:30am |
