Home > Wheels & Tyres > Replaced continental with Pirelli tyres - mistake? |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 |
This might sound mad but have you double checked the pressures? It really makes a big difference.
17th Feb 2018 8:23pm |
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 |
Check your pressures. Sounds like your garage may have over inflated the tyres. I think my fronts are at 32psi.. they were at 36 and drove awful, very bumpy twitchy and light. With 32psi, much better.. I am running 20's though... 2010 FF 4.4 TDV8 Vogue - Gone
17th Feb 2018 9:04pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
i run verde 255/55/20 at 36psi and floats like a dream i prefer them over the 50 and so better in the seat _____________________________________________________
17th Feb 2018 11:06pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I have Conti, 275/40/20 and run them on the low pressure / light load setting as there is only usually max 2 or 2 in the car - and usually just me. They are fine - yes they are firmer but not excessive. As said above check your pressures - and also check your gauge as I have one that runs 3 psi too much.
18th Feb 2018 7:47am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
Contis seem to have quite soft shoulders, hence these wear off quickly, but they do seem to give a quieter and softer feeling ride. Pirellis a bit firmer but more durable. The 2015 brochure says "if 22" wheels are fitted ride and road noise will be degraded on some coarser road surfaces, conversely steering and handling will be slightly improved on faster roads."
18th Feb 2018 6:39pm |
That's exactly why I bought an extra set of 285/50/20 on std L405 Wheels to compliment my 22's - they go on in the shooting season. The 285's give even more sidewall than a skinny L322 255/50/20 Tyre 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
18th Feb 2018 6:48pm |
