Home > Technical (L405) > Xenon-LED-Matrix Laser
Doodle
Read a report about complaints of excessive dazzle from LED headlights.
In certain weather conditions they can be distracting on country roads.
I had an Audi in 1998 with the relatively new Xenons and on dipped, would have hostile main beam blasts from oncoming vehicles.
It seems a similar pattern now occurs for LED headlights.
In 2014 Audi introduced Matrix Laser headlights which are claimed as being twice the range of LED's (albeit with advanced light distribution technology).
Ford are also developing advanced technology for improved LED distribution.
So, why do my 405 Xenon headlights sometimes seem too low a beam and lacking in strength?
The 322's and previous 405 seemed better. Is this something to do with the headlight leveling system?
I miss being able to give a quick and powerful high beam flash these days. Whistle
Post #468630 14th Feb 2018 7:55pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Good so its not just me. letters not necessarily in the right order
Post #468693 15th Feb 2018 10:23am
danp03
I also believe the 405 is lacking. My 322 was far better and both disco 5 and velar I’ve driven where another level. Does anyone know if there are stronger bulbs that can be fitted to the 405? Thanks.
Post #468824 16th Feb 2018 7:06am
Vogue
I also noticed this - my late 322 VSE also had far stronger headlights - I thought the 405's had been dimmed down for the auto dip feature as sometimes the auto dip is late reacting 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #468827 16th Feb 2018 7:32am
caymanblack
Guys have you tried adjusting the beam ? I did on my sport and they became the usual RR standard strong lights.
Post #468879 16th Feb 2018 1:54pm
Dixy
How letters not necessarily in the right order
Post #468883 16th Feb 2018 2:07pm
probably something like on the L322 Dixy,
Post #468895 16th Feb 2018 3:22pm
Doodle
Thanks for the info and Stan for the diagram. Will look into this.
Post #468953 16th Feb 2018 10:24pm
Dixy
No not the same letters not necessarily in the right order
Post #469016 17th Feb 2018 2:59pm
Bill
Ditto... so interested in the final solution. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #469053 17th Feb 2018 6:16pm
Doodle
Had a look and above the light cluster (under bonnet) sits a removable black plastic cover.
Nearest the grill, both near and offside show a dipped headlight and 1.2%. I assume this is % below horizontal.
If these plastic covers are removes, will I find something similar to Stan's diagram fro the 322?
Even if possible, not keen to reset % without proper setup, so will ask for dealer to check on service which will be April/May.
The headlight levelling sensor was replace about 18 months ago after pothole damage. Wonder if this has an influence?
Post #469345 19th Feb 2018 4:13pm
