![]() | Home > Technical (L322) > Air Suspension Inactive |
Engine running, turn steering fully to left, turn steering fully to right. Ignition off, ignition on and you should be ok. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
^ do that straight after a battery disconnect and reconnection ... ... - .- -.
The Pixie Member Since: 11 Feb 2018 Location: Cameroon Posts: 2 ![]() ![]() |
Tried the steering technique but suspension still inactive, no lights showing on dial either. |
Regrettably if you have no lights showing for the air suspension you have a hard fault logged on the ecu which means you need to connect to a diagnostic unit to clear it. |
