![]() | Home > Technical (L322) > Fed up with XENONS |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 386 ![]() ![]() ![]() |
I could never work out whether it was the ignitor or ballast resistor that was causing the problems. I ended up buying complete second-hand units [including balast resistor] from eBay for around £45-£55 per side which solved the problem.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Cheap enough
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 ![]() ![]() ![]() |
I had this randomly on either side and solved it by replacing the lighting module which works both lights.
