Home > Maintenance & Mods (L322) > 4.4TDV8 water/oil heat exchanger problems. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
To the best of my knowledge from compiling my 4.4tdv8 Fault log, no one has ever actually 100% proved that they have had the actual cooler casting leaking.
10th Feb 2018 4:52pm |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
That's encouraging, because they have now changed the gaskets.
10th Feb 2018 4:56pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
Hi, it took over a week to get rid of the smell I went to a car wash that had an underbody wash.
10th Feb 2018 5:12pm |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 |
Same here , i had mine replaced and it took a while to get all of the oil gone from all the nooks and crannys .
10th Feb 2018 5:14pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
Hope yours is sorted, but I saw my old unit had a crack in it when I was at the garage....so it does happen. They say they have done more than a dozen since..... 2011 Range Rover Vogue SE 4.4 TDV8
10th Feb 2018 6:25pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Yep just the gaskets and o rings done on mine a few weeks back and no new leaks that I can see. Plenty of oil still sitting in the vee from previously, but worst of the oil burn smell now gone. I don’t know if I’ll need to suck out the residual oil in the vee or whether that will go in time. Chris |
10th Feb 2018 7:44pm |
mjdronfield, out of interest, where abouts was the crack on your oil cooler? I’m guessing on the fins of the cooler somewhere? Chris |
10th Feb 2018 7:46pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
it was a good two~three weeks that smell remained on mine, especially going up steep hill, so if you can find some uphill roads do some spirited driving to get engine hot and burne that residual oil.
10th Feb 2018 9:52pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
stoutgoose I also have an unfound 4.4TDV8 leak. Wet bottom rear or engine. A hose at the front too, low down. O-rings have been done. Oil cooler's been done too so still looking.
11th Feb 2018 5:34am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
After replacing the gaskets in my oil cooler, I doused the V with engine degreaser and pressure-washed the area to remove any remaining oil.
11th Feb 2018 9:35am |
Apologies to mjdronfield. I must have missed your “crack “ report in the hundreds of other reports on various 4.4 tdV8 problems that I read. I dare say dealers must have found others, but also, having gone to the trouble of stripping everything down, I can understand that they have changed some good ones just to “be sure” they fix the problem leak.
11th Feb 2018 11:43am |
The saga continues.
14th Feb 2018 8:48pm |
If it was a straightforward change then I wouldn’t expect much coolant loss. When I changed my gaskets I had an added complication that the front coolant hose plastic connector that rises from the radiator broke, so having to change that hose resulted in a lot more coolant running out. There’s a bleed screw at the front but this will only expel air when the coolant is hot enough to run around the radiator. Don’t know if there’s any more on the engine block itself. Chris |
14th Feb 2018 8:56pm |
Sorry, seemed to have missed these updates
14th Feb 2018 10:46pm |
