Home > Maintenance & Mods (L322) > LOST WHEEL NUT SOCKET ( Locking Nuts)
honeyman
England 2006 Range Rover Vogue Td6 Java Black
Hi Help I today noticed brake light "on" decided to look at brake pads .... Butttt I cant find the locking nuts as I have lost the key socket .... Any suggestions Just remembered that it was not returned after having new tyres fitted
Post #467999 10th Feb 2018 1:55pm
dingg1
Main dealer usually carry a selection for you to match to your nuts
Oh err missus
Post #468000 10th Feb 2018 2:07pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
locking wheel nuts
Hi, There is a way to get them off but you will have to buy new wheel locks,
Find a socket that has multi splines not octagonal that is slightly smaller than the outside circumference and whack it on with a hammer it has to cut a tight grove into the outside of the locking wheel nut then just turn off as normal if it slips, try again or try a smaller socket. There is a Utube on this.
good luck
Post #468014 10th Feb 2018 4:44pm
Balloonengineer
My (apparently genuine) lock nuts were an internal multispline type which seemed so common, there doesn't seem much point having a locking wheel nut as they are all "keyed alike!" Find another FFRR owner and ask if you could borrow theirs.
I wouldn't bother replacing them with another set of locknuts, and just buy normal wheel nuts instead, and thank the heavens above the next time you get a puncture somewhere inconvenient.
Who's heard of alloy wheels being stolen anymore? I have jacked mine up without unlocking it, and yes it does set the alarm off as they are fitted with tilt sensors.
On the same note. I had a jaguar with a lost nut key. One with pins in random places (the nut has slots to match in random places). To get it off all you needed was a nut with one pin (cut all the others off) and that of course would undo any combinations of pins/slots!!!!
All these lock nuts do is prevent the owner, if thieves want your wheels, locknuts wont stop them if they have come armed with a jack and bricks, they will have also sorted a universal "key"
Best wishes
Glen
Post #468078 11th Feb 2018 10:18am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
In Australia we don't have range rover wheel thieves so I removed all lock nuts and replaced them with non locking ones to be safe knowing I can get them off when I need to .
Post #468103 11th Feb 2018 11:58am
rar110
Me too they are a PITA. ______________________________
Post #468198 11th Feb 2018 8:50pm
Sandyt
If you go into the main dealer take id and log book unless you know them they will usually give you one of their spares and order a new one in for themselves or worst case slacken them off for you
Then ditch them Thumbs Up
Post #468199 11th Feb 2018 8:54pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Have you checked all the cubby holes in the boot and looked under the spare wheel?
Wouldn’t be the first time, that it turned up in the car when assumed lost ... 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #468205 11th Feb 2018 9:23pm
You have a PM sir Thumbs Up
Post #468231 11th Feb 2018 11:42pm
