Home > Technical (L405) > heating problems RR Vogue SE 4.4TDV8 2013
Skennedy72
Northern Ireland 2013 Range Rover Vogue SE SDV8 Causeway Grey
HELP
HEATING PROBLEMS
Hi I am having heating problems
Car RR has been checked Rad leaks etc coolant all fine
Noting showing on computer or any faults
My heating will blow normal for about 5 mins or until car is at normal operating temp.
Then one side starts to blow cold even when heating is set to 28 and Synced
When temps are set not synced and all set individually to 28 this still happens
Then the drivers side will lower in temp to about 30 %
Rear heating is also about 30%
ANY IDEAS
RR dealer had car and they said £1500 to take out dash and investigate with out guarantee of fixing it
Post #467653 7th Feb 2018 1:06pm
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Any chance this could be the culprit !
http://www.fullfatrr.com/forum/topic46229.html Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #467693 7th Feb 2018 9:32pm
Skennedy72
Thanks will get my ex LR service guy to check and report back
Post #467697 7th Feb 2018 9:49pm
Sandyt
That valve set is located on the inner nearside wing and controls temp left and right it is after the heater matrix in the system - the fact that the temperature varies means it is probably working - when you say it is normal are you talking about the temperature or the speed of the blower ?
Post #467703 7th Feb 2018 10:09pm
Skennedy72
heater fans normal will go from low to high on demand
heat coming from vents from cold start build up to full heat before dropping off to cold.
normally when car temp reaches normal operation temp.
Post #467705 7th Feb 2018 10:12pm
