![]() | Home > Maintenance & Mods (L322) > Battery replacement |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
Not sure which year you have but later year L322s had AGM batteries as standard. On my 2011 the initial charge voltage is programmed at 14.7 volts which is too high for a wet battery and will exceed the recommended 6.0 amp charge rate of your yuasa 5000 019 110a and may damage the battery longer term.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
you're correct re the amps Tom.. |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Yes amps 100 for some reason predictive tex has a mind of its own . Bonnet cable fixed today all good only struggle was getting engine bay nipple out of carrier .So are you saying that this battery will not do ? |
Oh and my car is 03 4.4 bmw engine |
It should be fine for that year but just worth checking what the charging voltage is. IIRC it should be about 14.2V or thereabouts 2011 4.4 TDV8 Vogue SE
Yes voltage 14.2 .I have tried to kill this battery leaving lights on etc and she still turns engine fast as .So realy pleased {at the moment} |
