Home > In Car Electronics (L322) > Steering wheel volume control fault
Grizwold
United Kingdom 2012 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi
I’m new to the forum. I have a FFRR Vogue MY2012. The Steering wheel volume control raises and lowers the volume but changes the radio station at the same time, which I’m sure can’t be correct. Any thoughts on what it could be?
Thanks
Post #466689 31st Jan 2018 8:32am
GGDR
Welcome!
That's pretty annoying!
Try a battery reset which can often clear little gremlins.
Use the search ^^
Good luck,
Greg Cheers, Greg
Post #466690 31st Jan 2018 8:38am
Grizwold
Thanks Greg
I will give it a try.
Post #466691 31st Jan 2018 8:42am
big fingers?
try changing the volume with the edge of the d-pad, if the station still changes then the d-pad is faulty... ... - .- -.
Post #466695 31st Jan 2018 9:00am
Grizwold
Yep thought of that but have been very deliberate in the process and ruled that one out. Thanks
Post #466697 31st Jan 2018 9:09am
Things haven't changed then, my 2004 has exactly the same fault albeit on an intermittent basis. Thumbs Up
Post #466701 31st Jan 2018 10:18am
