Home > Maintenance & Mods (L322) > Sidelight not working
kbald
Hi had an intermittent check side light fault with my led ones and then the led bulb stopped working so thought it was blown. Bought new bulbs and replaced the faulty passengers side one but it still didn't work. Tried the bipulb in the other side and it works fine. All other lights in tne passengers side work fine so iam at a bit of a loss. All wires seem fine and i assume if it was a fuse others wouldnt be working too. Does anyone have any ideas what it could be at all?? The check side light error is on so i assume power is getting to the bulb holder. Current 2007 TDV8 Vogue Buckingham Blue
Post #466644 30th Jan 2018 7:47pm
if its a led bulb then try again and this time rotate it 180 degrees...you can also double check that power is going to the socket by putting one of the old incandescent ones in.. ... - .- -.
Post #466656 30th Jan 2018 8:19pm
kbald
Thanks i have tried a standard non led one and it doesn't work and used that same bulb in the other side and it works fine and have tried the bulb both ways round so am stumped. Will need to try a multi meter on the bulb holder to see if its getting power but they are all on the same connector so would seem strange one lead would fail. Current 2007 TDV8 Vogue Buckingham Blue
Post #466661 30th Jan 2018 8:39pm
a multi meter is a good shout...try moving the wire , there might be a break.. ... - .- -.
Post #466662 30th Jan 2018 8:41pm
kbald
Will do and will update if i get to the bottom of it. Current 2007 TDV8 Vogue Buckingham Blue
Post #466664 30th Jan 2018 8:58pm
