![]() | Home > Technical (L322) > Starting Issues |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 ![]() ![]() ![]() |
I had a problem with a starter motor that did exactly that. Wouldn’t start, hook up the jump pack; and away we went.
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Sounds like the usual tdv8 starter problem. had mine replaced under warranty and no problem after. Agueroooooooooo. 93-20
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6744 ![]() ![]() ![]() |
Possibly also a loose connection onto the battery.
C7 Member Since: 29 Jan 2018 Location: Hampshire Posts: 2 ![]() ![]() ![]() |
Yes, I had a starter motor replaced when the car was about six months old with a similar issue but this is far more intermittent, and always works with the jump pack. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1395 ![]() ![]() ![]() |
I had similar, intermittent non-starting, initially no click when starter button pressed, but after a while it started clicking, battery fine, was defective starter motor, it was replaced and now fine again. The problem seemed to involve the motor overheating. If you got a new motor in 2012/13 it may have become similarly defective. Only Range Rovers since 1988 |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I have a petrol but had a similar problem with my supercharged replaced the positive lead and problem solved - sometimes the leads corrode internally also worth taking both terminals off the battery cleaning and reseating so they are tight - could be poor connection and putting the jump pack on makes it good |
