![]() | Home > Technical (L322) > Isofix car seats |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Yes dead right they are a pain. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
They are hard and a tight fit I found getting one side pressed in first at an angle then pushing other in works using the front seat with my back pressed as leverage, also on other seat I use a seat belt with an isofix strap off the bay to go across the the bottom off the seat into the hooks. _____________________________________________________
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I fitted some latch guides to make life easier. See https://www.pramcentre.co.uk/car-seats-car...7EQAvD_BwE |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
Thank-you so much Martin, I didn’t realise these existed, just bought 2 to try but if it does what is says, it will be perfect…
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2666 ![]() ![]() |
I kind of poke my finger in the space between the seat back and base to make sure I'm lined up, practice makes perfect, and slightly pushing the seat foam down helps too. |
