Home > Technical (L322) > New MOT rules re DPF, should my aging TD6 be worried?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, heard there are new rules regarding DPF on diesels, will this effect our 2003 TD6 please?
Also, I was planning a EGR blank next month, is this related at all? (Excuse my lack of knowledge)
Post #466314 28th Jan 2018 9:51am
wack61
Egr blank will if they check , TD6 hasn't got a dpf
Post #466325 28th Jan 2018 10:47am
mjdronfield
Don’t think they can strip anything, so if you take the egr off and replace with the blanking kit they won’t see it..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #466345 28th Jan 2018 2:04pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
No engine covers or undertrays are removed in an MOT. Your TD6 does not have a DPF either.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #466443 29th Jan 2018 10:12am
mrblonde
Thanks guys Thumbs Up
Post #467672 7th Feb 2018 5:44pm
mrblonde
Just resurrecting this old posts guys, I read earlier about if any smoke it visable from the exhaust its a fail too on the new MOT, does this sound right?
If so, i thought most old diesels smoked a bit?
Post #474992 6th Apr 2018 10:43am
As far as I know the visible smoke point only applies to vehicles fitted with DPFs
For cars not fitted with such a device the mot is as before ie smoke test only.
Post #474999 6th Apr 2018 11:52am
Mikey
As above Thumbs Up
Post #475003 6th Apr 2018 12:31pm
nearlee
Wales
So when where dpf started appearing on ff's.
Ad the misses saab has one fitted and that's an 06 model Remember:- amateurs built the ark
Proffesionals built the titanic
Post #475052 6th Apr 2018 7:50pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
In the UK, it was with the introduction of the 4.4 TdV8; it was optional on the 2010 3.6 version, but not many took it up. Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #475065 7th Apr 2018 4:49am
YEV1989
United Kingdom 2008 Range Rover Autobiography TDV8 Stornoway Grey
My 2008 L322 3.6TDV8 has a DPF and I'm very much worried about the subjective visible smoke test. MOT due 22/12/2018.
Has anyone else had experience of the visible smoke test. Hopefully the tester will employ a reasonalbe level of common sense.
Cheers
Paul
Post #496182 21st Nov 2018 1:04pm
