Home > Maintenance & Mods (L322) > Changing the CV boot? |
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 |
Local independent quoting £100 plus vat, Sounds very fair. |
30th Jan 2018 1:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
It is a bit of a job, you are more or less removing the hub to get it out which means tackling the lower arm joint which can give a fight, and having the right socket to undo the the drive shaft nut! and a hub puller to release the spline.
30th Jan 2018 2:04pm |
What else would you look at while it's being done? |
30th Jan 2018 4:33pm |
Really it is all the joints and bushes on the hub or on the links to the front subframe. If the lower arm joint is tight (read forum member stories!), it may get knackered anyway to allow removal! .
30th Jan 2018 4:38pm |
