Home > Maintenance & Mods (L322) > My Battery finally gave up after 9 years.. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
What was it?
24th Jan 2018 2:42pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
It was made by Schnapp.
24th Jan 2018 3:39pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I've been through 3 in the same time period, and the third is just starting to show its age, or I have a parasitic leak... .
24th Jan 2018 6:03pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Im curious, do you know how they define “lifetime”? |
24th Jan 2018 7:23pm |
Ah ha:
24th Jan 2018 7:32pm |
They didn't ask me what vehicle the "lifetime" battery was being fitted to.
25th Jan 2018 10:11am |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
I was wondering; what is considered a normal lifetime for a battery these days? Specifically, an AGM battery fitted to a 2011 TDV8 4.4. I'm asking because mine is now 6 ish years old, and is showing 12.1 volts at rest according to my multimeter. The car starts fine, there's no warning symbols, but should I be budgeting for a new battery? They're £200 and it looks very tricky to fit the darned thing!
25th Jan 2018 10:44am |
Usually somewhere between 2 and 5 years, depending on use, battery quality and dumb luck!
25th Jan 2018 4:45pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
COB 12.1 volts means it's on its last legs. Mine's similar (also 2011 AGM / TDV8) I think 12.3 at rest.
25th Jan 2018 4:58pm |
Hmm, that what I thought GG DoubleR; I think 12.6 volts is nearer the mark for a healthy battery. Oh well, that's life I suppose. I must say, Land Rover don't make it easy on these late model TDV8s; reading the wiki there are all sorts of gubbins to remove, a battery ECU (just why?), clamps, brackets.......and then you have to use the IID tool to tell it there's a new battery.
25th Jan 2018 7:06pm |
On the voltmeter, there's only a fine difference between ok and knackered:
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
25th Jan 2018 8:07pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 803 |
Mine has been on 12.1 for the last 4 years.....
25th Jan 2018 11:04pm |
