Home > Technical (L322) > Boot light unplugged.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Boot light wasn't working, so I popped it out and found that the little plastic power plug was not connected and tucked away behind some other wiring. Plugged it in and it works perfectly fine (switches off when boot locked, etc).
I didn't get the impression that the plug had come adrift accidentally (through vibration or whatnot) as it is quite secure when plugged in.
So, what reason could there be for someone deliberately unplugging the boot light and tucking the connecting cable neatly out of the way?
Is it a known battery drain or something?
Post #465912 24th Jan 2018 8:23pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
To a fellow wulfrun-ian, i can only speak personally.
I have unplugged certain lights, purely to reduce battery drain when I'm mooching around in the boot.
It also reduces nosey neighbours seeing me putting bodies in the boot. Very Happy 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #465922 24th Jan 2018 9:29pm
Gyre8
Haha, OK, Thanks Jake. Give me a toot and a wave if you see a Tonga Green '06 FFRR passing.
Post #465924 24th Jan 2018 10:03pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
A lot of resellers unplug the boot light so that they can leave the boot open all day on the forecourt. They seem to think it will make us notice the cars more or something. I’ve never understood the logic. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #465935 24th Jan 2018 10:45pm
Gyre8
Thanks steveball. Sounds logical.
Post #465936 24th Jan 2018 10:52pm
miggit
Shocked What a waste of time... my ffrr always turned the lights off after about 30 minutes! Yesterday I couldn't spell Engineer... Today I are one!
Post #465982 25th Jan 2018 1:34pm
jakebullet64
Gyre8, do you have a FFRR sticker on? 2003 Range Rover Vogue 4.4 on Gas
Post #466000 25th Jan 2018 3:23pm
Gyre8
No FFRR sticker. I've been put off by the tales of the difficulty of applying them correctly (level, unwrinkled, etc). I couldn't stand it if it wasn't level.
Plus I have a mild dislike of stickers on a car. One thing I do when I buy a used car is religiously remove all the stickers. I've still got a previous owners National Trust sticker on the windscreen - whose days are numbered.
Post #466002 25th Jan 2018 4:09pm
jakebullet64
haha, national trust, on a thirsty V8 -the irony 2003 Range Rover Vogue 4.4 on Gas
Post #466173 26th Jan 2018 8:47pm
Mr Tee
My first one never switched the boot light off hence the disconnection. Newer one semis to swith off..
Post #466214 27th Jan 2018 7:40am
miggit
Shocked Maybe it's a CCF thing? Mine was a 2003! Yesterday I couldn't spell Engineer... Today I are one!
Post #466224 27th Jan 2018 8:49am
