Home > Technical (L322) > Lumpy running |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
What model L322? ______________________________
23rd Jan 2018 8:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
i'd check them hose's ... - .- -.
23rd Jan 2018 8:14pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
10 plate tdV8 according to his sig |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 |
Yes, 2010 MY L322 3.6 TDV8
23rd Jan 2018 8:26pm |
Also, problem disappears under hard acceleration... but is pronounced under idle and very light throttle. __
23rd Jan 2018 8:31pm |
Anyone else have ideas on this?
24th Jan 2018 10:08pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hate to say it, but that sounds like some unhappy injectors... But I could still be suffering from Roverphobia Yesterday I couldn't spell Engineer... Today I are one!
25th Jan 2018 1:37pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Sound like an injector fault to me.
25th Jan 2018 1:46pm |
I'll get it booked into a specialist then!
25th Jan 2018 3:36pm |
My TD6 had I very occasional lumpy tick over which gradually got worse to the point it was doing it all the time.
25th Jan 2018 4:38pm |
If your car is reasonably low mileage then you could try some injector cleaner, but if it's anywhere neer 100k +/- 20k then I'd suspect the injectors could do with a deep clean and testing on a test rig. If you're not doing the removal yourself then I'd suggest either a trusted indy, or a Bosch Service Centre..... 2 reasons for this, you'll save on the labor and importantly the Stealers will not fit recon injectors, they'll just replace with new and charge you the equivalent of a full clean and test by the diesel specialist per injector...... so if you want to pay up to 8x too much you know where to take it Yesterday I couldn't spell Engineer... Today I are one!
26th Jan 2018 10:16am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Don’t be too hasty removing the injectors either as the seals and pipes need replacing each time they are removed and that adds up too!!! £100 ish each cylinder springs to mind, but it has been some time since we last did some... |
26th Jan 2018 10:32am |
Specialist found 3 injectors well out of tolerance and are changing them as I type. __
30th Jan 2018 4:06pm |
No wonder it wasn't happy!
30th Jan 2018 9:30pm |
