Home > Technical (L322) > Camera module related fault codes (2010 autobiography) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2502 |
The surround camera module is underneath the front passenger seat. |
22nd Jan 2018 11:58pm |
23rd Jan 2018 12:04am |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Thanks Graeme that's just what I was after.
23rd Jan 2018 12:54am |
It will activate on specific canbus messages. |
23rd Jan 2018 1:38am |
Thanks.
23rd Jan 2018 8:57am |
The letter P after the fuse number indicates the Passenger compartment fuse panel. E=engine, R=rear.
23rd Jan 2018 11:25am |
OK, thanks.
23rd Jan 2018 1:02pm |
Does it have surround cameras or only a rear camera? If only a rear camera then no surround camera module will be fitted.
23rd Jan 2018 8:29pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 900 |
Just a thought.......when the battery was replaced, did the owner perform the battery reset procedure (start engine, turn steering all the way left, hold for a couple seconds, then all the way right and hold for a couple seconds)?
23rd Jan 2018 10:20pm |
Hi guys.
24th Jan 2018 12:28am |
Just trying to eliminate the obvious first.
24th Jan 2018 9:04am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Stan has written how to disconnect/ reconnect battery, it is in the Wiki, may be worth a try. |
24th Jan 2018 9:21am |
Thanks guys.
24th Jan 2018 12:48pm |
