Home > Technical (L322) > Suspension live data using Allcomms, seems like odd readings
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
My ff seems to be sitting level.
I do have a recurring fault that sends the air suspension inactive.
The fault reads too much regulation needed right rear, so I suspect I need a new airbag on the right rear.
What I cannot get my head around though are the live readings from each corner. They seem so widely different, I can't believe that they are correct. This is what I get:
Front left -29441
Front right +2
Rear left 0
Rear right +2560
can anyone make sense of these, or alternatively, anyone with an Allcomms and full working suspension care to take a look at their live data for the suspension and tell me what yours shows.
Cheers all RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #465571 22nd Jan 2018 2:53pm
This image from Storey Wilson's (RSW SOlutions) video on calibration
So, yes, something doesn't look quite right with your numbers .
Post #465582 22nd Jan 2018 4:41pm
NVB
Thanks for that. I havent seen that screen, probably cos I'm too scared to enter the calibration function, so got mine from live data. Perhaps I'll have a look at the calibration screen, as it appears you can view without making changes.
I have also email Storey, so will update with any info I get from him.
If anyone does have the Allcomms and can look at their live data I would appreciate it.
Cheers RR History
Post #465586 22nd Jan 2018 5:01pm
Won't get a chance til the weekend now... .
Post #465596 22nd Jan 2018 6:38pm
GraemeS
Re: Suspension live data using Allcomms, seems like odd read
A new height sensor perhaps but not a new airbag/air-spring.
Post #465611 22nd Jan 2018 7:49pm
Matt Pearce
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
Front left -29441
Front right +2
Rear left 0
Rear right +2560
Cheers all
I have very similar readings on my RR looking at my All Comms live data.
when you check the live volts on the Front Left height sensor are they up in the 40s ( wh3n connected)?
if so you have the same fault as me.. so at least i can let you know what doesnt work so far!
i cant readily read live height volts on All Comms, i am using my Carsoft i930 hand held which works really well as an assistant to my All Comms..
I think Storey has given up on me, he doesnt respond to my email problems @nymore .. and i dint blame him.
Post #466328 28th Jan 2018 11:02am
khyber
United States 2004 Range Rover HSE 4.4 V8 Zambezi Silver
I have very similar issue. Was there a resolution?
Post #637609 22nd Jul 2022 10:22pm
