Home > Maintenance & Mods (L322) > Roof Coutesy Lights
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Roof Coutesy Lights
My rear roof courtesy light has stopped working when the door is opened, it functions fine if you use the switch,
proving that power and bulb are ok.
I have tried the "hold the button for three seconds" to switch the mode from 'off' to 'auto'. This works on the front lights but not on the rear passengers set.
Nothing similar appears from a search, any ideas?
Many thanks.
Post #465365 21st Jan 2018 12:40pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Daft suggestion maybe ...
Have you tried switching them on with the switch.
Then get out, lock car, unlock car. What do I put here then?
Post #465377 21st Jan 2018 2:20pm
as above, switch them on, leave on and lock/unlock... .. Thumbs Up ... - .- -.
Post #465386 21st Jan 2018 3:09pm
millerj90
Thanks guys.
That partially worked, the rear courtesy lights operate when locking or unlocking the car, but stay on after engine start, weird.
Post #465404 21st Jan 2018 4:26pm
they should stay on for a short while..did you wait long enough to see them go out.. ... - .- -.
Post #465413 21st Jan 2018 5:31pm
millerj90
I think so Stan, the front went out almost immediately in engine start, and I waited for the rear to follow suit, perhaps as you suggest, not long enough. I’ll give it another go tomorrow.
Many thanks.
Post #465415 21st Jan 2018 5:41pm
