Home > Technical (L322) > Abs fault
Coffey12
United Kingdom 2003 Range Rover Vogue Td6 Barolo Black
Abs fault
Hi ffrr, i’m having problems with my 2003 td6.
When i drive the car sometimes the hdc inactive air suspension inactive and abs lights come on the abs cuts in whilst driving and the car begins to brake with the brake pressure rising. I’ve plugged the car in to a abs obd reader and fault code given is PRESSURE SENSOR OFFSET
I still get a reading from the pressure sensor. I’m kinda thinking the precharge pump isn’t cutting off some how?
So far i’ve replaced the abs module, brake light switch and had a new battery fitted.
As silly as it sounds if all the tyre pressures arn’t checked adjusted daily it seems to happen more
Post #464807 16th Jan 2018 8:56pm
Dolphinboy
Someone else has had exactly this. Do a search on here and you should find it easily enough. Thumbs Up
Post #464823 16th Jan 2018 9:55pm
Coffey12
I’ve been searching through but all i can find is threads with no answers to the fault 🤔
Post #464829 16th Jan 2018 10:21pm
Dolphinboy
http://www.fullfatrr.com/forum/topic45968.html
does this help?
Post #464898 17th Jan 2018 2:59pm
Coffey12
Hi mate, this shows corrosion at the multiplug, mine looks okay and i have replaced the abs pump also already.
Post #464903 17th Jan 2018 4:03pm
