Home > Maintenance & Mods (L322) > Ignition Problem ?
07 Vogue Dublin
Ireland 2007 Range Rover Vogue TDV8 Stornoway Grey
Ignition Problem ?
I have a 2007 L322 Vogue, 3.6 TDV8 . about a month ago I had a problem where the RR wouldn't start, No dash lights like Battery etc. when I turned the Key, I did however get the dash screen , Windows, Radio etc. to turn on and I could move the Selector to any position. but the RR would not start. So I got on to the Dealer that I bought it from and he said it was possibly the Battery, I checked the symptoms on the Internet and yes it was 1 of the possibilities, so off I went and bought a battery, put it in and No Difference.... Still wouldn't start. Then I got a Specialist Auto Electrician, he spent 2 days , stripped out and traced all the Wiring , checked for broken or damaged cables, Nothing found other than some type of moisture on a plug under the Handbrake switch. In the process of re assembling the interior the dash lights came back on and the RR started.
That's not the end of this one just yet.... It worked with the problem showing its head only intermittently up to today when the RR has refused to start again with the same fault, no Dash lights when you turn on the Ign with the Key , engine will not turn over , but all the other electrics in the RR work as they should except that the Electric Handbrake will not engage.
At this point I am lost , Has anyone else had this problem and more importantly have they resolved it . Any help would be greatly appreciated........ Thanks in advance.
Post #464483 13th Jan 2018 11:27pm
07 Vogue Dublin
URGENT ........ Part No. Required
I have found a post outlining the exact same problem , it is the ignition Switch and apparently it is a common problem with the 2007 V8 . My problem is finding a replacement switch or even a Part No. so I can search the net . If someone has the part no. or can tell me how to find the No. or knows where I can buy a replacement Switch i would be very grateful as my Vogue is sitting in the Garden and wont start.......
Thanks in advance....
Post #464602 14th Jan 2018 11:01pm
cass
I would just go with either Duckworths or a local main dealer- I can’t remember the price when I got one but I’m sure it wasn’t silly money
Post #464607 15th Jan 2018 12:25am
07 Vogue Dublin
Thanks
Thanks Cass, I contacted duckworths this morning and ordered the Switch.... £99 delivered inc Vat.
Thanks again....
Post #464670 15th Jan 2018 4:29pm
