![]() | Home > Technical (L322) > webasto |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
search 'fbh' or 'fuel burning heater' or have a look in the wiki.... |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Front LHS behind wheel arch liner - easy to access, moderately easy to remove and reinstall |
Hi
The webasto turns on every time I park, but turns off again after 1 minute.
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
Looks like a typical webasto ecu problem
Sure, that would be great.
Back to the webasto topic.
Sounds like it is not firing up. Do you hear the fan start up when you open your door? If so then it is your (pcb?) card - the electronic circuit board. Needs refurb or replacing. Best guy is mike on the Rover 75 site. The contact details are on here somewhere. Search FBH |
yeah. it fires up. Ill check the pcb -03V td6
If it is firing up then The glow plug must be working and it may be too coked up to continue so a de-coke May be in order. These bits of kit do produce a lot of soot apparently. |
Hi Dolphinboy
Not an expert on these by any means but the exhaust tube and general burn area gets full of soot after a while and needs cleaning out as it impedes burning of the fuel and causes an early cessation/fault. |
