Home > Maintenance & Mods (L322) > grinding brakes
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
grinding brakes
hi guys
i have got a nasty grinding noise coming from my brakes when i lightly put my foot on brake when i am about to pull away and slow down . it dose not grind at all when i lift off . went to local garage and was told this was normal for automatics ,i have never heard this before and think i may have been fobbed off,help please .........had new pads about 350 miles ago
Post #464157 11th Jan 2018 1:13pm
CS
It's not normal. If the pistons in the caliper are corroded when the new pads are installed, the pistons can stick, as the rough corroded end is pushed back into the caliper when the thicker new pad is inserted. There can also be damage to the dust seals which again can jam the pistons. Occasionally some debris gets trapped between pad and disc, but that should make a noise all the time, and generally drop out before too long. Wheels heating up would be a sign of sticking brakes. Further (honest and competent) examination required. Only Range Rovers since 1988
Post #464163 11th Jan 2018 1:54pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I wouldn't go back to that garage as it is not normal for automatics. Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #464164 11th Jan 2018 2:00pm
Harlin
thanks guys ,didn t think it was right but then i am a mere carpenter
Post #464166 11th Jan 2018 2:07pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Might just be a light coating of rust because its been stood a while, worse in winter, in laws clio auto was terrible for it first touch of the brakes in the winter.
Post #464171 11th Jan 2018 3:42pm
Danwilderspin
I had something similar - don’t drive anywhere until you have checked - in my case the two halves of the front discs had come apart Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464174 11th Jan 2018 3:46pm
miggit
If the brake pads are not correctly made you can end up with the pad just sticking above the disc.. this produces a little limp on the pad and it makes a similar noise to what you've described... you'd need to pop a wheel off to see, but if there is any pad going over the top of the disc, knock it off with a screwdriver / chisel or the like! Yesterday I couldn't spell Engineer... Today I are one!
Post #464321 12th Jan 2018 7:37pm
