Home > Orders (L405) > Configurator Accessories?
This topic is locked: you cannot edit posts or make replies.  Down to end
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
On the Land Rover configurator while building, there is a tab / stage towards the end called "Accessories". This includes various extras such as Luggage Dividers, Illuminated Tread Plates, Side Steps and Aluminium Gearshift Paddles.
These appear to show as "Dealer Fit" extras - My question is, do these need to be ordered with the car, or can you just order these at anytime from your local dealer?
Also, it's the Aluminium Gearshift Paddles which I'm considering - Would these be fitted at factory or by the dealer, and if it is by the local dealer, do they have to take the steering wheel off to fit these?
Post #463862 8th Jan 2018 11:41pm
emilio
Malta 2012 Range Rover Westminster TDV8 Orkney Grey
As theyre accessoreis they can be fitted at a later date. Dunno if paddles is a steering wheel off job.
Post #463870 9th Jan 2018 5:22am
Hodog16
United States
Paddles are a DIY thing. Steering wheel can stay on. I parked the car with the steering wheel turned a quarter turn and it’s a hex screw holding the paddle in place. Once freed there’s a single wire clip that’s easy to exchange. 2021 Mercedes G63 - Cardinal Red/Classic Red
2016 Range Rover Sport Supercharged Dynamic - Firenze Red/Pimento [Traded]
Post #464359 13th Jan 2018 12:52am
aja500
That's great to know - Thanks Hodog 16.
I'll see how I feel about the black plastic ones when they arrive and maybe change at a later date.
Are you pleased you changed Hodog16? - Are you happy with the quality and feel of the aluminum?
Post #464415 13th Jan 2018 2:47pm
Hodog16
United States
Yes, very happy with the aluminum. I went with red. Much better than the plastic. 2021 Mercedes G63 - Cardinal Red/Classic Red
Post #464422 13th Jan 2018 3:38pm
Fat Wolfie
Might be worth a quick chat with your dealer first though - my previous 405 AB had silver coloured paddles, which I had assumed were aluminium (and certainly felt like a higher quality item than the black plastic ones in my loaner Vogue).
Looking in the brochure all the pictures of the AB interior show “aluminium “ paddles but also says “ ...with some options...” but helpfully doesn’t give you any ideas as to what they are.
I suppose it might be worth configuring a Vogue and then an AB to see if the interior pictures change?
Just would be galling to buy something that was already included...
Post #464428 13th Jan 2018 4:19pm
aja500
Thanks for your reply Hodog16 - You too also Fat Wolfie, thats a very good point you make, I will see what it comes with to start and add if necessary
Post #464489 13th Jan 2018 11:59pm
This topic is locked: you cannot edit posts or make replies.  Back to top
