![]() | Home > Technical (L322) > access height |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1202 ![]() ![]() ![]() |
Hi, I wonder if anyone can shine a light on my problem when I press the switch on the door to select access height I get fault light and bong.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
When the ignition is on, can you select the off road height from the centre console ? V8 or else ... |
HI, Fisha
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
Knowing the fault code produced would likely be useful. |
Ok, I will check out the code tomorrow and report back.
