![]() | Home > In Car Electronics (L322) > Reverse camera |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
You'll need one of these! https://www.disco3.co.uk/shop/nav-screen-c...e-p34.html
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 ![]() ![]() ![]() |
brilliant I have already installed the camera and loom and connected it up to the head unit as what Ballon engineer has done in the number plate lamp holder but i found that the camera was both NTSC/PAL and couldnt find one that did NTSC only and wanted to make sure that what iwas going to buy for the third time was the right one |
NTSC produces a smaller picture, which the screen is setup for, when you go PAL the Picture is larger and the screen appears to start in the middle of the picture and work it's way out... the only problem is it runs out of screen! Yesterday I couldn't spell Engineer... Today I are one!
cheers miggit for that i will order the correct one on pay day
Are but with all those dam roundabouts you don't really get a rush hour traffic jam, except the couple of roundabouts that they have put lights on... you can go across the city in less than 15 minutes... not many built up areas can boast 10 miles in 15 minutes |
