![]() | Home > Technical (L322) > Stubborn arb.. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
PTFE spray and a bigger socket and bar |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
Thin slitting disc in an angle grinder to cut through ARB arm retaining nut & stud thread ? Paul,
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Defo thin cutting disc and andgle grinder. Did this on the rears that wouldnt budge and was much tighter space wise! Just be careful and take it slow and break the ball up with a chisel ie cut in a slit twist repeat until it brakes free. Current 2007 TDV8 Vogue Buckingham Blue |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Dremel like tool works well. |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Thor’s hammer for the win 😂 ended up cracking it after days of getting soaked in penetrating fluid and I used a 5 foot bar. Horrible crack then was able to slowly move it.. passenger sides now failed so will have to repeat at the weekend. At least I know what to expect again lol |
Sorry the breaker bar was for the hub/strut knuckle lower bolt. Drop link one was cut. |
