Home > Technical (L322) > intermittent abs/hdc/eas issue solved. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
great fix pal , good of you to share it with everyone |
1st Jan 2018 2:04pm |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Nice one 2006MY 4.2 SC
1st Jan 2018 5:10pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Well found CovBandit, one to add to the list of things to look for .
1st Jan 2018 5:22pm |
Tg87 Member Since: 09 May 2019 Location: Suffolk Posts: 21 |
I think I’ve got a similar issue. I recently purchased a pair of aerosus bags for the front after one went pop.
2nd Jun 2019 9:42am |
Covbandit Member Since: 10 Jan 2016 Location: Coventry Posts: 104 |
Hi, due to the months of hassles, and the now cheapness of the complete strut, it was just the most cost effective, plus the aerosus was just out of warranty, and the time it takes to strip and rebuild I just felt for the sake of 20 quid more change the lot. I only changed the one to begin with but changed the other side about 6 months later, so far touch wood they have been hassle free. The leak on the air bag inside was definitely a manufacturing fault as there is no access to damage it, also I think the tolerances are slightly off with the large o rings on the strut as mine leaked from there also.
2nd Jun 2019 2:28pm |
Thanks, that definitely helps. Did you buy the struts from aerosus or somewhere else? Just wondering if it was a manufacturing fault if it was worth trying somewhere else. |
3rd Jun 2019 5:30am |
Aerosus messed me about from the start really, sent me the wrong side then refunded PayPal after charging me for the correct one etc. . I sourced my struts from the well known auction site, without looking through all my receipts etc I am sure these are the people I used
3rd Jun 2019 7:31am |
Excellent, thanks! I’ll get them ordered and start the fight with aerosus for a refund! I doubt I’ll get one but they don’t work so I’m not sure what they could say to get out of it. |
3rd Jun 2019 8:25am |
Ok pal, good luck all round. |
3rd Jun 2019 11:35am |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
I fitted these to my Td6 done both fronts, cheaper than others only took me 30 mins to fit from start to finish per side. A lot easier than just changing the air bags 2004 Autobiography TD6 Java Black |
4th Jun 2019 3:08pm |
Excellent, I’ve ordered them and to their credit Aerosus are actually giving me a refund for the leaky bags.
4th Jun 2019 3:12pm |
If you have not done one before they are a doddle, just make sure you get the orientation right. I was unlucky with mine it was about 2 months out of warranty! So didn't even try. But fair play |
4th Jun 2019 3:28pm |
How do you mean get the orientation right? Replacing the whole strut or just the bag?
4th Jun 2019 7:32pm |
The new ring on the compressor sorry |
4th Jun 2019 9:30pm |
