Home > Technical (L405) > Weak jets - windscreen wash
pld118
Is it just ours or is the pressure quite low and weak when using the windscreen wash, particularly at motorway speed?
Post #462404 28th Dec 2017 6:20am
bear100
mine are really good and deliver a powerful fine droplet which covers the whole screen, same for the head lights Thumbs Up 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #462405 28th Dec 2017 7:05am
pld118
Thanks bear, they do work but the spray seems to hit just underneath the wipers and seems more like a mist as opposed to a strong jet. Maybe they need to be adjusted Thumbs Up
Post #462407 28th Dec 2017 7:30am
CS
Assuming your screen wash is concentrated enough not to be freezing, and the nozzle heating is not defective, the problem might be nozzles clogged with polish or other dirt. They can be cleaned out (and redirected) with something like a darning needle. Only Range Rovers since 1988
Post #462445 28th Dec 2017 12:51pm
pld118
Thanks CS, the reservoirs are always full of concentrated screen wash so definitely not frozen.
Will try the tips.
Post #462450 28th Dec 2017 1:22pm
If you have a compressor, disconnect the rubber pipework under the bonnet and give them a good blast through Thumbs Up
Post #462451 28th Dec 2017 1:25pm
pld118
I do have a compressor Craig. Wouldn't have thought of that one cheers Thumbs Up
Post #462468 28th Dec 2017 2:55pm
Thumbs Up Thumbs Up Thumbs Up
Post #462555 28th Dec 2017 11:31pm
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
Interestingly I just had washer jets replaced under warranty as they were hitting the trailing edge of the bonnet. It was an improvement but not perfect. Only noticed while I was replacing wiper blades with Piaa Aero Vogue which incidentally are brilliant.
Post #462720 30th Dec 2017 1:59pm
