Home > Technical (L405) > Tailgate only opens half way. |
Pixelpower Member Since: 16 Jul 2014 Location: Droitwich Posts: 204 |
Mine did that, and still does occasionally. The first time the dealer sorted it out. Now it seems to reset itself after closing again. Maybe they updated the software. |
28th Dec 2017 9:21am |
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 |
Hi does it always stop at the same point ? Is it possible you have programmed it to do so accidentlally by restricting it opening one time? Try pressing the button again when it stops until it is fully open then keep your finger on the button to store the new opennng height. Worth a try. I have had a couple of issues with mine but always the bottom section never the top. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
28th Dec 2017 9:34am |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 406 |
Yes, exactly the same about half way each time.I tried holding the button down and all it does is try and close, |
28th Dec 2017 11:47am |
ADI Member Since: 13 Oct 2017 Location: South Yorkshire Posts: 70 |
I would try manually opening to full height as highlighted below
28th Dec 2017 1:45pm |
Thanks Andrew, all restored to normal.
30th Dec 2017 4:04pm |
