Home > Technical (L322) > How do Adaptive Dynamics dampers work?
TomCobbly
Just out of technical interest do the dampers use magnetorheological damping or something else?
may have spelled that wrong! Embarassed 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #461630 21st Dec 2017 1:58pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Yes, magnetorheological - Delphi/BWI MagneRide.
Post #461649 21st Dec 2017 3:43pm
TomCobbly
Thanks for confirming. That must be what the wires are for! Smile
Bet they are expensive!! 2011 4.4 TDV8 Vogue SE
Post #461653 21st Dec 2017 4:01pm
VERY expensive yes sir Whistle Whistle Whistle Bow down
Post #461658 21st Dec 2017 4:12pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Very interesting how these posts tend to clump together!
Do the Range Rovers have another chip in them that follows the forum and when someone puts a post up it thinks' Hmmm Adaptive Dampers question! I know, lets break them!!'
Post #461662 21st Dec 2017 4:38pm
GraemeS
According to the WSM the dampers have an orifice that bypasses the valves. The orifice opening is ecu-controlled.
Extract from the WSM:
The adaptive dynamics dampers are monotube, nitrogen gas and oil filled units. The dampers are continuously variable, which allows
the damping force to be electrically adjusted when the vehicle is being driven. The dampers provide the optimum compromise
between vehicle control and ride comfort. To maintain wheel travel, the rear dampers feature an additional external accumulator. This is to provide adequate rebound travel by recovering the volume through the external source. All the dampers have an electrical
connector on the end of the piston rod, in the center of the top mount.
In each damper, the damping adjustment is achieved by a solenoid operated variable orifice, which opens up an alternative path for
oil flow within the damper. When de-energized the bypass is closed and all the oil flows through the main (firm) piston. When
energized the solenoid moves an armature and control blade, which work against a spring. The control blade incorporates an orifice
which slides inside a sintered housing to open up the bypass as required. In compression, oil flows from the lower portion of the damper through a hollow piston rod, a separate soft (comfort) valve, the slider housing and orifice and into the upper portion of the
damper, thereby bypassing the main (firm) valve. In rebound the oil flows in the opposite direction.
In the firm setting oil flows through the main (firm) valve only, but when the bypass is opened by any amount the oil flows through
both valves in a pressure balance. When fully energized the solenoid moves the armature and therefore the slider to the maximum
extension and opens the orifice completely. The damper operates continuously between these two boundary conditions.
The solenoid in each damper is operated by a 526 Hz PWM signal from the ADM. When fully energized, the ADM applies a 1.5 A
current to operate the damper in the soft setting. When de-energized (0.0 A) the damper is in the firm setting. The current varies
continuously as required to increase and decrease the damping individually in each of the dampers.
Usng my IIDtoool, I have recalibrated mine a couple of times on different surfaces to vary the damping between too soft and too firm.
Post #461712 21st Dec 2017 8:01pm
thats interesting re the calibration, how do you do that then? ... - .- -.
Post #461717 21st Dec 2017 8:26pm
TomCobbly
Well they are nothing like the way magnetorheological dampers work. They work by changing the viscosity of the fluid in the damper by applying a magnetic field controlled by an ecu........ apparently!
So which type do I have then? 2011 4.4 TDV8 Vogue SE
Post #461718 21st Dec 2017 8:31pm
Baltic Blue
GraemeS,
Thanks for the explanation, it certainly accounts for the noticeable change in ride comfort when the wires break.👍👍
Cheers
Post #461732 21st Dec 2017 9:39pm
TomCobbly
Looks like I have the nitrogen gas and oil filled units as described by GreameS. I wonder if the Delphi MagneRide ones can be fitted when the time comes to replace the originals. Even if they fitted I guess they use a different ecu. 2011 4.4 TDV8 Vogue SE
Post #461738 21st Dec 2017 10:13pm
GraemeS
My IIDtool under CALIBRATION lists adaptive dynamics. At 'continue yes/no', 10 seconds of calibration starts when Yes is selected so the vehicle needs to be driving on a suitable surface. If stationary then the result will be excessively soft dampers or if driving on very rough off-road conditions then the dampers will be excessively firm, so somewhere in between is needed. The IIDtool does not provide the ability to restore the original calibrations, presumably as no defaults exist within the control unit.
Post #461756 21st Dec 2017 11:41pm
thanks graeme.. Thumbs Up
so on a smooth road the dampers will calibrate to soft...if, after calibrating like this you go onto a rough road, will it be a softer ride? ... - .- -.
Post #461763 22nd Dec 2017 6:53am
GraemeS
A softer ride but perhaps wallowing, even on secondary roads not necessarily particularly rough roads. Striking the right balance might take a few calibrations. If the ride is too soft then find a bumpier surface for another calibration, perhaps noting what stretches of road are used so that in future when they get too soft, another calibration can be done on the same stretch of road to restore the desired ride. Mine had deteriorated to the point that I was about to order a pair of Bilstein replacements for the rear to see if they tidied-up the ride enough to warrant replacing the fronts too, but found the calibration option just in time. When they eventually are too worn to do a proper job and new ones fitted then another calibration will be needed otherwise the ride will be far too firm.
Post #461772 22nd Dec 2017 7:36am
didnt think of the possible 'wallow' effect..i think i'll leave well alone in case i mess it up...thanks chap Wink ... - .- -.
Post #461775 22nd Dec 2017 7:43am
Philip
Interesting - this is a cutaway from the 2010 press pack, which shows what looks like (I think) a Bilstein DampTronic damper (as per the manual excerpt above). Most part numbers for the combined shock/bag/strut unit suggest BWI/Delphi as OEM though.
Post #461821 22nd Dec 2017 3:10pm
