![]() | Home > Technical (L322) > Heated Seats Keep Turning Themselves Off? |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
id say there is a fault of some kind pal , though it usually turns them off a lot quicker than that |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
Mines much the same, worked fine all summer but now I really need it. If it comes on at all its only for about 30seconds before the fan stops spinning. Can anybody help me out - a cold bum is no joke |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1394 ![]() ![]() ![]() |
My recollection from the manual is that because the seats are hard on the battery they switch themselves off automatically if the battery is getting a bit low, it might be worth checking if that is right and, if yes, whether your battery could do with a charge. Only Range Rovers since 1988 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
My steering wheel occasionally switches off and won't switch back on again until the ignition is cycled.
Passenger one works fine all of the time - I've never had a problem with the heated wheel, however, occasionally the screen heater doesn't switch on and I think that may be battery related. I think when it gets a bit warmer I'll strip it down to investigate although as I said it seems to work when its warmer. In the meantime I will charge the battery anyway and see if it makes a difference - Thanks guys |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Lots on this if you use the search function. Also how do.you know if seats are turning off after 10 mins ?? could it be less ? 2015 4.4 AB
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Are you sure that it is turning off? Do the lights on the switch extinguish?
Heated and cooled seats in my case and not 10mins more like 30secs, the lights stay on but the fan stops and the seat doesn't get warm.Thanks to Dolph34, there is plenty on this (I don't know why I didn't use the search in the first place - doh!) Symptoms suggest a cracked air pipe so I'll have a look and see if I can sort out some sort of repair if needed. Both myself and previous owner were not the lightest of people (sorry Mark) and so it seems that the pipe may well be the culprit and certainly worth a look. Can anyone who's done this (and I can see that a few have) help - can I just look under the seat or do I have to remove the back as well (not sure I know how to do this). Geoff |
Hi Geoff, back needs to come off and units location is very obvious , just above the rear map pocket geographically. Very straight forward job. Some instructions say you need to remove headrest but this is not necessary. My unit was irreparable but i had a replacement ready.
If the lights stay on, then the issue could simply be a crack in the air ducting from the seat fan. The system turns itself off to protect the Peltier cell.
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
Sorry guys, been away from my computer for the last couple of days - Thank you all for your advice and experience with regards to this problem, seems it's not just me. I'll have a look through all the info above and see if I can pinpoint the problem / solution.
I think I hijacked this thread a little (unintentionally - Sorry aja500) so I will hopefully get my seat out over Christmas and report back my findings. Geoff |
No not at all supershuttle - Have a great Christmas |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
I've had exactly the same problem and (I think) fixed it this evening.
