Home > Technical (L322) > Slowly getting there
apparently rob... Rolling Eyes
Post #45777 12th Jan 2011 4:21pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
scarey wrote:
@rrv....nah!!
Quality Laughing If you have nothing nice to say,say nothing at all.
Post #45781 12th Jan 2011 4:34pm
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Had the car up on the ramps yesterday, there is nothing at all loose ! Doing my head in 2007 TDV8 Vogue SE
Post #46146 15th Jan 2011 11:03am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
It will be the ball joints or bushes in the lower arm. Had both my arms swapped and similar knock went away.
The wa wa wa wa .... is that when you have the rear windows open given that its warm over there? If so its just turbulance and negative pressure waves... sounds like a chinook following you?
If not does the Wa wa wa wa noise go when you brake? If so it could be the sliders on the caliper sticking.. I had this.. Removed caliper clean and lube slider with copper slip and de-crud the caliper. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #46148 15th Jan 2011 11:24am
David
the wa wa wa wa wa wa it not when the window is open, it comes from the under the car at the front in the middle ?
Ill check all the other stuff again when we do the pads.
Maybee i need to let it develop a bit more ! 2007 TDV8 Vogue SE
Post #46224 16th Jan 2011 11:20am
