![]() | Home > Maintenance & Mods (L322) > Streaks on windscreen |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Worn / micro scratches due to wiper blades not being changed very often...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
there's a link in the ebay section for aero wipers, cost around £17 for the pair.. ... - .- -.
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Thats the thing Craig.. I do replace them regularly and hardly ever have to use the wipers as I have a polymer coating which why I am confused.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
Even if you've changed the blades regularly, the old style blades have the branching arms / fingers which put the pressure down on the rubber unevenly, which is why you're seeing the uneven wear.
Yeah.. deffo worth a try I think..
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I took Craig's post as meaning to replace the screen. 2017 5.0 Autobiography Supercharged
Yikes !!!!! Current:
The wiper blades were the ones listed in this thread...
Superb... ordered and will report back.
Ok guys.. got my wipers delivered and fitted them fairly easily.. couldnt save the plastic it has said there for so many years.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I think they gave the wiper arm a tweek (twist) to get the blade to sit squarer to the screen.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I think we used to be able to be adjust the angle on the wiper where It bolts on. I think they may have changed that on the later arms tho, I can’t remember. There is nothing that can't be fixed with a hammer😜😜
These are the non hook ones and all the thread I have read do not suggest the wiper arm needs a mod. I think it may be a bad wiper.. will report back. Current:
