Home > General > Range Rover Experience - I broke the 4.4!
scene247
I can't wait. Still trying to get booked in at eastnor castle.
But worrying on the brake front. And odd too as if it works with HDC then brakes are actually working but something wrong pedal to brake connection...?
Post #46121 14th Jan 2011 11:12pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
HDC operates the ABS system and the traction control by fly by wire systems so you don't need the hydraulic bits! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #46125 15th Jan 2011 5:28am
That's interesting but confused as to what applies the pressure to the brake calliper cylinders if the brake hydraulics are not doing it in HDC?
Believe you just interested Exclamation
Post #46130 15th Jan 2011 8:56am
T24RES
I don't think Kevin knew the answer at all. Once out of the mucky stuff and pumped the brakes the pressure returned. Another example of the FFRR gremlins? Hygroscopic? Someone cooked the fluid?
Good job my life didn't depend on them........... Surprised Ian
Post #46131 15th Jan 2011 9:09am
Out of interest where the brakes perfect on the road test drive? They were fine when I was driving as just as well as we tested the adaptive cruise by pulling in behind a slower car at high speed Big Cry
Post #46132 15th Jan 2011 9:14am
T24RES
He did recall the adaptive cruise testing Whistle Tbh i didn't do the road test, just the mucky stuff. Ian
Post #46136 15th Jan 2011 9:42am
