Home > Technical (L322) > Bad sensor? Iid tool help
alistairh
Ok car ended up on front bump stops last night . Prior to this a few days before it wouldn’t let me use access mode . I had new tyres fitted a week before and I’m now wondering if a sensors away..I can inflate every corner apart from the drivers side right with iid tool as well..!because the iid tool won’t read voltages on corners on an 2004 plate how do we rule out a bad height sensor?
Post #461026 16th Dec 2017 12:12pm
Are you sure you don't have a leak in the FR airbag?
Have you checked to see if sensor/s still intact / attached /connected?
No error codes or EAS warnings on the dash ?
All EAS lights on centre dash working OK ?
Live readings on EAS ? .
Post #461049 16th Dec 2017 3:39pm
alistairh
Hi joe. Yeah arms in correct place and it’s connected. No dash warnings and nothing stored in ecu. It will select off-road ect but simply doesn’t move..
Post #461055 16th Dec 2017 4:06pm
