![]() | Home > Maintenance & Mods (L405) > I’ve got to fix those useless standard reversing lamps!! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
Something mounted in the tow bar receiver and plugged into the towing electrics ? |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Thanks. There are certainly options around the tow bar, but the lower a lamp is, the less effective it is |
If you install auxiliary lights at low level below the bumper you can achieve the desired light spread by simply pointing them up a few degrees from horizontal. Works for me on my L322. |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I've thought about this a bit. I considered taking off the plastic cover in the centre of the rear bumper and putting a row of LEDs in there.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
My daughter had a similar problem with her Fiat 500... A reversing light that would make a 405’s look positively day light!
All interesting stuff, thanks for your replies and ideas |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1104 ![]() ![]() |
Like Craig I fitted a set of Ring LED DLRs just under the bumper and wired it in to the tow hitch, worked a treat, find the lights adequate on the 405. letters not necessarily in the right order |
Pictures? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
If it is just for occasional problem situations I wonder whether you could get a suction fitting lamp that works off the towbar electrics or else a power socket inside the car with the wire through a window or jammed in the door (the seals should stand up to that occasionally) and attach it to the roof or the back of the car? That sort of thing is sold by gamekeeper supply businesses (in connection with lamping rabbits and foxes) and there are probably work lights too. If you have roof bars then maybe something could be clamped to the rear bar, there are also suction bars to which a lamp could be clamped. I have not tried this myself, but do have to reverse in dark farmyards with random machinery standing about occasionally, so sympathise. It is a significant reason for my not having privacy glass, as I suspect it does not help in that sort of situation. Only Range Rovers since 1988 |
originalracingsnake Member Since: 14 Jul 2017 Location: Gloucestershire Posts: 19 ![]() ![]() ![]() |
LED strip under the high level brake light?
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1456 ![]() ![]() |
It strikes me that the many designers of the FFRR (L322, L405 et al) have a blind spot (pun intended!) when it comes to the reversing lights.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
LR vehicles arnt the only car manufactre's that have small reverse lights ..another bugbear are the small indicators as well.. ... - .- -.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1631 ![]() ![]() ![]() |
I’m resurrecting this thread because no-one seemed to come up with a neat solution, or at least they weren’t proud enough to post pictures.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 192 ![]() ![]() ![]() |
I have the same dillemma, I am looking at some LED reverse lights from Powerfuluk but I'm not sure about the look of the 3 LED's, has anyone fitted these, if so, how obvious are the circles on the lens and how is the light output.
