Home > Maintenance & Mods (L322) > 2010 3.6 tdv8 random flat battery
Rob199027
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi there
Today at the pub my Range Rover dedcided to have a flat battery, been using lately as normal, jumped in it this evening battery died, think time for new battery as when I bought I’m the car in August the car stood for about a month we had to jump it then, so could this now be my battery is braking down in the cold weather ? Any suggestions on a decent battery ?
Cheers
Post #460661 12th Dec 2017 11:24pm
NyxsteRR
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Yep, exactly the same thing happened to my car about 2 weeks ago when the cold weather started. Garage came out and the battery was down to 6 volts and not holding a charge. They replaced it with an Exide 105 stop/start I think - they brought a exide 115 but it wouldn't fit. The car was on its OEM factory unit so 7 years was a pretty good life. New battery has been fine since.
Post #460931 15th Dec 2017 2:26pm
Bluegreygreen Rangie
Australia
Put the biggest battery in you can.. and i know it's an ongoing debate on these forums but imo put an agm battery in!, Lasting longer when sitting is one thing the agm is very good at
Also do you always lock your car when not in use?.. It shuts down most power draining devices when you do as apposed to it sitting unlocked which some people may do in a garage situation
I don't think it would hurt to check your alternator output also as they seem to go on these cars often (replaced mine this evening/ same car) ... Just check bat voltage .. then start it and take notes of the voltage reading over the next few minutes... i think it's safe to say you want to see at least 13.5 volts 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #460937 15th Dec 2017 3:28pm
Rob199027
Hi guys
Aa man came
Out checked the battery and everything was ok and holding charge
He put it down to my misses only
Does short trips in the car and because now got all heaters on seats steering wheel etc the battery is not getting properly charged back up again
But going to get a AGM battery as I hear that they do the trick
Cheers for advice guys Thumbs Up
Post #460940 15th Dec 2017 3:44pm
