![]() | Home > Technical (L322) > FBH cold from rear vents |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 ![]() ![]() ![]() |
I have a strange problem with the parking heater on my 2010 VSE. The FBH was replaced under warranty a year or so ago and fires up with no problem at all. When it works, the windscreen and front floor vents produce warm air, however the rear centre vents pump out cold air so the cabin doesn't really warm up at all.
Thanks for the reply - yes mine does have the AGM battery with the reduced running time. I was surprised it was putting any air out of the rear vents as well. Everything I have read suggests it should only be the front vents. Makes me think one of the flaps is stuck open or something like that which is forcing air to the rear when it shouldn’t be. |
As the colder weather has been here a while I am still trying to find out if I have a fault or not with the rear passenger face vents with the parking heating ...is there anybody that could quickly test for me? Can you stick your hand in front of the rear passenger vents when the parking heater is running to see if hey have any air coming out of them and if so is it hot or cold!
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
Just checked in mine.
Was going to add...
Thanks for that, very much appreciated - seems like the software “upgrade” has changed things and that perhaps mine is operating normally. As you say perhaps wishful thinking on a toasty warm cabin! Incidentally last week it was -2 and even after a 40 min drive my washer jets were still not working, now wondering if that has anything to do with the mirror heating you mentioned below. |
I would use a better screen wash then ! |
Fair point! |
