Home > Maintenance & Mods (L322) > Help ! Driver door handle not working
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
After a 12 hour night shift i cant open the drivers door , it opened initially but now sat about halfway out , it wont shut at all , just bounces ? Iced up ?
Post #460097 9th Dec 2017 10:55am
frozen lock mechanism ..happened to me and i took t out and put loads of grease in there to help stop it freezing.. ... - .- -.
Post #460099 9th Dec 2017 11:10am
bembo449
Ok , thought it mite be , sat and locked / unlocked via the dash button and walah ! Its back to normal , yay
Thanks pal
Post #460101 9th Dec 2017 11:16am
fisha
I used to be able to free it up with WD40 skooshed in about the lock area when it happened to me, that and a hair dryer. V8 or else ...
Post #460122 9th Dec 2017 4:01pm
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Happened to me, I also sprayed wd40 in and around the locks, hasn't happened since.
Post #460129 9th Dec 2017 5:25pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Happened to me this morning.
I had to close the door, pulling it too and then press the interior lock button to keep it closed and locked so I could drive off!
I'll be lubing it up as said above.
Post #460149 9th Dec 2017 9:23pm
mine was so bad that when i actually got the door open it wouldnt close and lock so i had to drive with one hand on the door keeping it closed until the lock un-froze.. ... - .- -.
Post #460151 9th Dec 2017 9:34pm
bembo449
where exactly do I need to spray the WD ??
Post #460535 12th Dec 2017 2:08pm
