Home > Technical (L322) > My 2010 6hp26 improvements?
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
LR advertised that the 2010 Ffrr models had an improved 6 speed gearbox! Does anyone know what mods were done or was the 6hp32 fitted?
Laurie
Post #459998 8th Dec 2017 12:36am
Mikey
I believe (but stand to be corrected) they fitted the 6HP28
Post #460000 8th Dec 2017 8:01am
thats correct mikey Thumbs Up
Post #460004 8th Dec 2017 9:24am
rar110
Did they have two different spec versions of the 6 speed in the same production year? ______________________________
Post #460008 8th Dec 2017 10:44am
RRPhil
ZF upgraded the three versions of their 6HP transmission to ‘2nd generation’ models. All the model numbers increased by two i.e. the 19 went to 21, 26 to 28 & 32 to 34.
https://www.zf.com/corporate/en_de/product...sion.shtml
The diesel got the new 8-speed transmission when the 4.4 TDV8 engine superseded the 3.6
Phil
Post #460010 8th Dec 2017 10:47am
rar110
Thanks Phil.
So the 2010 3.6 tdv8 got the 6hp26 or 28, like the 2010 5.0 v8?
I’m interested as my 08 tdv8 26 suffered the output spline rusting and wear, and trans and transfer case were replaced with a unit from a 2010 3.6.
I had to swap in the mechatronic from my old trans. ______________________________
Post #460011 8th Dec 2017 10:56am
j_rov
the 2010 diesel has the 6hp26 box doesn't it? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #460033 8th Dec 2017 1:49pm
rar110
I suspect you’re right J, and JLR has two different spec 6hp2#’s for the two different motors. ______________________________
Post #460155 9th Dec 2017 9:25pm
Mikey
rar110 wrote:
Thanks Phil.
I believe the mechanical parts are interchangeable, but the electronics are not.
Pre/Post 2010MY have different CAN networks, and are not compatible, hence the need to swap the mechatronic unit over Thumbs Up
Post #460160 9th Dec 2017 10:54pm
rar110
Yes, the plan is to eventually swap over the valve body but keep the old TCM. Apparently the TCM can be detached and swapped over from the valve body. ______________________________
Post #460162 9th Dec 2017 11:02pm
